  • David Armitage 510 posts 2082 karma points
    Jun 14, 2021 @ 12:33
    David Armitage
    Umbraco 9 Composing Inside Custom Classes and Razor without Dependency Injection
    Hey All,
    Does anyone know how to compose services and helpers inside custom classes or razor views without using dependency injection.
    As a reminder the old way we used to do that i Umbraco 8 was like the following..
    @using Current = Umbraco.Web.Composing.Current IBlogHelper _blogHelper = Current.Factory.GetInstance
    Regards
    David
  • Bjarke Berg 29 posts 265 karma points hq
    Jun 14, 2021 @ 12:51
    Bjarke Berg
    You cannot.. (and should not :P)
    Dependency injection (DI) is supported in the web framework, so in views you can just do something like
    @inject IBlogHelper _blogHelper
    DI is also supported for filters etc.
    Jun 17, 2021 @ 07:09
    David Armitage
    Thanks Bjarke.
    I will give this a go. Its great that these now get injected into razor views like this now.
