  • a 8 posts 88 karma points
    Aug 06, 2021 @ 16:09
    a
    Creating a menu system in Umbraco 9
    Previously when creating a Navigation partial I was able to use this type of syntax.
    @{ var homePage = Model.AncestorOrSelf
    Also could use and then all I had to do was loop through
    @foreach (var page in Model.AncestorOrSelf(1).Children.Where(x => x.IsVisible()))
    I am now attempting this in Umbraco 9 and all I get is this un helpful error
    'ViewsPartials__Navigation' does not contain a definition for 'AncestorOrSelf' and the best extension method overload 'PublishedContentExtensions.AncestorOrSelf
    Could anybody enlighten me please.
    Thanks in advance.
  • Bjarke Berg 29 posts 265 karma points hq
    Aug 06, 2021 @ 16:13
    Bjarke Berg
    It sounds like you do not have a using of
    Umbraco.Extensions
    In the view or the _ViewImports.cshtml
    Aug 09, 2021 @ 08:45
    a
    Hello, thank you for replying. Both _ViewImports and my partial have the @using Umbraco.Extensions;
    Maybe I am missing something in the appsettings.json file? I am fairly new to CMS Umbraco so even the IPublished is a bit confusing.
