  • Roman Kalius 6 posts 76 karma points
    Nov 10, 2021 @ 08:48
    Roman Kalius
    Content picker created in js - problem after migration 8->9
    hi, im new in umbraco cms, so I cant find the solution. After migration from v8 to v9 out content picker throw excepiton:
    when I set udi value - Its empty editor
    in v8 it works fine:
    editors are created in js file dynamically ( based ona data we received ) below its scrap of code:
    js.file:
    var alContentPicker = {
                alias: 'alContentPicker',
                label: '',
                description: '',
                view: 'contentpicker',
                config: {
                    minNumber: 0,
                    maxNumber: 0,
                    multiPicker: '0',
                    filter: config.allowedTypes
    angular.forEach(config.columns.columns,
                    function (value, key)
    if (value.type === "contentpicker") {
                            var contentpicker = angular.copy(alContentPicker );
                            contentpicker.alias = contentpicker.alias + columnKey;
                            if (value.props.multiple) {
                                contentpicker.config.multiPicker = '1';
                            $scope.contentpickers["c" + columnKey] = contentpicker;
                            $scope.$watch('contentpickers["c' + columnKey + '"].value',
                                function (newVal, oldVal) {
                                    console.log($scope.contentpickers);
                                    if (newVal || newVal != oldVal) {
                                        $scope.rowdata[value.alias] = newVal.toString();
                            if (editing === true) {
                                $scope.contentpickers["c" + columnKey].value = rowdata[value.alias].toString();
    html.file:
    umb-property-editor model="contentpickers['c'+$index]" ></umb-property-editor
    I will be grateful for any help
    Nov 14, 2021 @ 11:40
    Marc Goodson
    Hi Roman
    I'm not sure if this of any help, but the error message talks about an issue converting an integer 5612 into type Umbraco.Cms.Core.Udi which is the unique guid key for identifying an item.
    Before Udi's were introduced the Content Picker would store the integer Id of the content item from the database - but the Udis were introduced to help with uniqueness between different Umbraco environments (eg for Umbraco Deploy).
    But both exist for backwards compatibility.
    So I'm not sure if something has changed in V9 but the Content Picker has a configuration option called idType that determines whether the Content Picker works with 'udis' or with integers...
    https://github.com/umbraco/Umbraco-CMS/blob/5bfab13dc5a268714aad2426a2b68ab5561a6407/src/Umbraco.Infrastructure/PropertyEditors/ContentPickerConfigurationEditor.cs#L29
    I guess here perhaps in V9 the default has switched to be Udis? and you need to add the idType config for your generated pickers?
    contentpicker.config.idType = 'udi';
    or the other way around!
    Said it might not be a helpful observation :-P
    Update.... Also saw this open issue... https://github.com/umbraco/Umbraco-CMS/issues/11631
    regards
    Marc
    Nov 17, 2021 @ 13:16
    Marc Goodson
    Hi Roman
    Just to follow up on this... it's a bug in Umbraco 9.1RC / 9.1 release
    The workaround to create a new Macro Parameter Editor that supports Udi's is detailed here:
    https://github.com/umbraco/Umbraco-CMS/issues/11631#issuecomment-970148965
    Looks likely it will be fixed in a later 9.1.1 release.
    regards
    Marc
    Dec 01, 2021 @ 08:24
    Roman Kalius
    hi, the solution was to setup contentpicker.config.idType = 'udi' and to convert int's to uid in database. Thanx a lot for help
