  • Charles 3 posts 83 karma points
    Nov 15, 2021 @ 14:11
    Charles
    Umbraco 9 - Unable render view with model
    I have enabled the models builder, ModelsMode = SourceCodeAuto.
    Currently I have created a Document type named as Home and published a page named as Home as well.
    However, I got the below message when I view my page. The type or namespace name 'Home' does not exist in the namespace 'Umbraco.Cms.Web.Common.PublishedModels' (are you missing an assembly reference?)
    Here is how I call the model. @using Umbraco.Cms.Web.Common.PublishedModels; @inherits Umbraco.Cms.Web.Common.Views.UmbracoViewPage
  • Kevin Meilander 82 posts 408 karma points MVP c-trib
    Nov 16, 2021 @ 00:34
    Kevin Meilander
    Assuming you see the source code file, try rebuilding your project after you generated the model class. You may also need to restart your website instance so it can get the updates.
    That always trips me up.
    Nov 16, 2021 @ 12:35
    Charles
    Hi Kevin,
    Yes, it works after I rebuild my project.
    Thanks!
