Different output result from 9.0 to 9.1 when using .Url(culture)
After upgrade I've noticed different results when using .Url(culture) on IPublishedContent.
State:
I have a Umbraco site, which has a single language en-US, site node, doesn't have any hostnames set to it. None of my content currently varies by culture.
When I fetch a published node and want to retrieve its URL for specific culture (UmbracoContext.Domains.DefaultCulture):
In Umbraco 9.0 - I would get the actual URL node, the same result as just .Url() without culture.
In Umbraco 9.1 - .Url() returns the expected result same as 9.0, but when specifying culture as the parameter, the result is #.
Allright, after some investigation, it looks like 9.1 is sensitive to casing of culture name, 9.0 didn't care much if it was en-us or en-US, but 9.1 does care, it must be en-US when using .Url(culture).
.Url(culture)onIPublishedContent.State: I have a Umbraco site, which has a single language
en-US, site node, doesn't have any hostnames set to it. None of my content currently varies by culture.When I fetch a published node and want to retrieve its URL for specific culture (UmbracoContext.Domains.DefaultCulture):
Url()without culture.In Umbraco 9.1 -
.Url()returns the expected result same as 9.0, but when specifying culture as the parameter, the result is#.Can somebody please explain what has changed?
Thanks in advance
en-usoren-US, but 9.1 does care, it must been-USwhen using .Url(culture).Looks like the fix is coming in 9.4: https://github.com/umbraco/Umbraco-CMS/pull/11886
