  • stefanie27 14 posts 72 karma points
    Nov 28, 2021 @ 10:42
    stefanie27
    Using Sendgrid as SMTP in Umbraco 9
    Hello Umbraco community,
    I want to use Sendgrid as SMTP for my Umbraco v9 website. I can see, how to configure the information here: https://our.umbraco.com/documentation/umbraco-cloud/Set-up/SMTP-settings/#configure-smtp-settings
    I assume it uses username and password for basic authentication.
    In following Sendgrid article it's mentioned that basic authentication isn't supported anymore. https://docs.sendgrid.com/for-developers/sending-email/authentication#basic-authentication
    Did someone use Sendgrid SMTP in Umbraco 9, which uses API Key (Authorization: Bearer 'Your-API-Key-Here') for authentication?
    Regards, Stefanie.
  • Kenneth Solberg 227 posts 418 karma points
    Nov 28, 2021 @ 13:52
    Kenneth Solberg
    You can use Sendgrid as an SMTP Server. You'll find the instructions here:
    https://docs.sendgrid.com/for-developers/sending-email/integrating-with-the-smtp-api
    "Umbraco": {
        "CMS": {
            "Global": {
                "Smtp": {
                    "From": "person@umbraco.dk",
                    "Host": "smtp.sendgrid.net",
                    "Username": "apikey",
                    "Password":  "generated-api-key-here"
    Also make sure configure Sender authentication for the domain you'll send from to prevent mail from ending in the recipients spam folder.
    Nov 28, 2021 @ 14:23
    stefanie27
    Hi Kenneth,
    Thanks for getting back to me.
    I understand that part from the Umbraco and Sendgrid documentation. I just want to get clarification, if the authentication in Umbraco for SMTP is Basic authentication (Which isn't supported in Sendgrid anymore according to https://docs.sendgrid.com/for-developers/sending-email/authentication#basic-authentication)?
    Regards, Stefanie.
  • Brian Freeman 1 post 21 karma points
    Apr 21, 2022 @ 22:31
    Brian Freeman
    The link is about the web api, not smtp protocol
