Hi there,
I am having an issue of the StartNodeId getting overriden during usync import on the test server.
The media are manually added in each environment. Every time I deploy, the starting node of the media picker gets overriden when I import using Usync.
Is there a way to fix this?
If you have certain data types that you don't want to be overwritten by uSync you can exclude them by alias (or by editor type) in the config.
http://usync.jumoo.co.uk/docs/reference/handlers#handler-settings
For example: In the config you can stop the config from being synced by uSync by either: The name of the datatypes (comma separated list). or the Actual Property Editor (again comma separated).
"uSync" :{ "Sets": { "Default": { "Handlers": { "DataTypeHandler" : { "Settings" : { "NoConfigNames": "About Us - Work Environment Image Picker", "NoConfigEditor", "Umbraco.MediaPicker" } } } } } }
Thank you for your reply Kevin!
I have added the following to appsettings.json and it worked.
"uSync": { "Settings": { "ExportOnSave": "None", "UIEnabledGroups": "Settings" }, "Sets": { "Default": { "HandlerDefaults": { "Settings": { "IgnoreAliases": "About Us - Work Environment Image Picker" } } } }
However, the following didn't work, wondering if I did something wrong:
"uSync": { "Settings": { "ExportOnSave": "None", "UIEnabledGroups": "Settings" }, "Sets": { "Default": { "Handlers": { "DataTypesHandler": { "Settings": { "NoConfigNames": "About Us - Work Environment Image Picker", "NoConfigEditors": "Umbraco.MediaPicker3" } } } } }
Starting Node gets overriden for Media picker using Usync import (Umbraco v9)
Hi there,
