Hi im trying to create a twitter feed on my umbraco website which is ruuning locally on my laptop. However after installing the package and setting up an application using twitter developers. I have done all the necessary things like created a Consumer key, Consumer secret, Access token, Access token secret and copied them over into dictionary but im getting the following error message
System.IO.FileNotFoundException: Could not load file or assembly
'TweetSharp, Version=2.0.0.0, Culture=neutral,
PublicKeyToken=c148cfb*********' or one of its dependencies. The system
cannot find the file specified.
File name: 'TweetSharp, Version=2.0.0.0, Culture=neutral,
at uTweets.Tweets.GetTweets()
at ASP._Page_macroScripts_uTweet_ListOfTweets_cshtml.Execute() in
c:\inetpub\wwwroot\umbraco
6\macroScripts\uTweet.ListOfTweets.cshtml:line 8
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value
[HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind
failure logging.
To turn this feature off, remove the registry value
[HKLM\Software\Microsoft\Fusion!EnableLog].
Ive tried this but still had no luck
Start REGEDIT and navigate to
HKEY_LOCAL_MACHINE\Software\Microsoft\Fusion and choose Edit -> New
-> DWORD Value. Name it EnableLog. Right click the new value,
choose Modify and set the value to 1.
If the EnableLog value already exists just set it to a value of 1.
Problem installing twitter package
System.IO.FileNotFoundException: Could not load file or assembly 'TweetSharp, Version=2.0.0.0, Culture=neutral, PublicKeyToken=c148cfb*********' or one of its dependencies. The system cannot find the file specified. File name: 'TweetSharp, Version=2.0.0.0, Culture=neutral, PublicKeyToken=c148cfb*********' at uTweets.Tweets.GetTweets() at ASP._Page_macroScripts_uTweet_ListOfTweets_cshtml.Execute() in c:\inetpub\wwwroot\umbraco 6\macroScripts\uTweet.ListOfTweets.cshtml:line 8 WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Start REGEDIT and navigate to HKEY_LOCAL_MACHINE\Software\Microsoft\Fusion and choose Edit -> New -> DWORD Value. Name it EnableLog. Right click the new value, choose Modify and set the value to 1.
Any help please????
Maybe it's better to use one of the new Umbraco Twitter packages for this?
uTwit
TwitterOAuthOap
Jeroen
Hi Jeroen,
Thanks for your reply I will give uTwit a try
Paul
