  • Cesare Salerno 3 posts 73 karma points
    Jun 18, 2018 @ 10:04
    Cesare Salerno
    Problem with netstandard 2.0
    Hello everyone, For some days we have had problems with our project on umbraco Cloud (https://dev-wkit-shop.s1.umbraco.io/).
    The error that is returned to us is as follows: enter image description here
    Our application uses the .Net Framework 4.7.1 which should automatically include the dependency on netstandard 2.0.
    Given that a few days ago everything worked correctly, have any changes been made in the configuration of the umbraco cloud environment?
    Do you have any suggestions on how to solve this error?
    Thank you
  • Ayo Adesina 445 posts 1059 karma points
    Jun 18, 2018 @ 11:34
    Ayo Adesina
    Is it working Locally?
    Have you logged on to your umbraco cloud portal? Do you have any extraction errors?
    Jun 18, 2018 @ 12:25
    Cesare Salerno
    Yes it is working.
    How to extract errors from umbraco cloud portal?
