    Oct 15, 2018 @ 11:43
    Dave Woestenborghs
    Custom data as part of content flow
    I have some data in custom tables that I want to be deployed using content flow in my cloud projects.
    How would I do this ?
    I had a look at ValueConverters but that is meant to be used for transfering content from a specific property editor.
    My data will be used inside the content (eg placeholder text) and needs to be transfered as well ?
    Is it even possible to transfer custom data on Umbraco Cloud between environments ?
    Dave
    Oct 15, 2018 @ 12:18
    Ismail Mayat
    Maybe use migrations?
    Oct 15, 2018 @ 12:21
    Dave Woestenborghs
    Migrations are ideal for setting up stuff on install.
    This is data that will be managed by editors... so don't see how migrations can handle this.
    I'm want to package up something we built for placeholder text, but then with out depending on doctypes. I want to store them in a database table.
    Dave
  • Ansar 181 posts 291 karma points
    Apr 29, 2019 @ 10:09
    Ansar
    Did you find a solution?
    I am looking for a way to deploy Dev to Live with data on custom tables (UCommerce). Just want to send data to live environment for the first time.
    Apr 29, 2019 @ 10:40
    Dave Woestenborghs
    HI Anz,
    Nope not yet. But for you uCommerce it maybe better to use their support channels.
    Dave
