Courier not publishing Checkboxlist property values
I have a data type that uses the CheckBoxList property editor. Courier correctly publishes all other properties of my content node (as far as I know) except this one.
I found the issue:
There was a comma in one of the checkboxlist's prevalues. When the comma was removed, Courier published the items correctly.
There is a similar item in Issue Tracker (COU-358) related to dropdownlist -- I believe this to be the same issue with checkboxlist, so I've made a note in the comments of COU-358.
I'm having the same problem, and I don't have any commas in my prevalues. I have about 40 pages that use the same template, and I'd say about half will transfer the checkboxlist values when using Courier.
I have to go into the destination environment and set the values manually, and every time I courier those files, the values get wiped out.
Any ideas?
Anyone have any ideas?
Bump... anyone have any ideas? No responses?
I found the issue: There was a comma in one of the checkboxlist's prevalues. When the comma was removed, Courier published the items correctly.
Any ideas?
