I believe Courier and Contour (aka, Umbraco Forms) use the same licensing system (i.e., the Umbraco.Licensing.dll file). I have had issues on a number of my sites where Contour simply does not recognize the license for some reason (I get tons of entries in umbraco.licensing.log.txt saying the license is invalid).
I'm not aware of a fix. I did report the bug to the core team (via the issue tracker, the forum, and their support system when logged into Umbraco.com), but they never responded with a fix.
Using Courier behind load balancer
The license is failing. This is my configuration:
does this makes any sense to anyone?
Umbraco.Licensing.dllfile). I have had issues on a number of my sites where Contour simply does not recognize the license for some reason (I get tons of entries inumbraco.licensing.log.txtsaying the license is invalid).I'm not aware of a fix. I did report the bug to the core team (via the issue tracker, the forum, and their support system when logged into Umbraco.com), but they never responded with a fix.
For your reference: https://our.umbraco.org/forum/umbraco-pro/contour/73098-contour-submissions-super-slow-3-000-db-calls-17-000-lines-in-licensing-log
