  • Dan Evans 631 posts 1018 karma points
    May 06, 2016 @ 15:15
    Dan Evans
    Courier data integrity fix
    Running U 7.4.3 and Courier 2.52.4
    I have followed the instructions here:
    https://our.umbraco.org/documentation/Add-ons/UmbracoCourier/DataIntegrity
    This fixes the issue - however, every few days it comes back again and I need to run the SQL fix.
    Is there an additional problem here?
    May 06, 2016 @ 16:57
    Dennis Aaen
    Hi Dan,
    If you still see the issue in Courier 2.52.4 then I would recommend you to create a issue on the tracker http://issues.umbraco.org/issues/COU and describe your issue, so it can be fixed once for all :-)
    Best,
    /Dennis
    May 06, 2016 @ 16:59
