I have facing courier time out issue.
Umbraco Version : 7.3.0
Courier Version : 2.52.7
Getting following error in Log :
2016-07-06 14:24:24,829 [154] DEBUG Umbraco.Courier.RepositoryProviders.Local - [Thread 147] Disposing: True 2016-07-06 14:24:24,829 [154] WARN Umbraco.Courier.RepositoryProviders.Local - [Thread 147] Closing session called but there is no session open: cd9d748f-c9e2-416a-8804-46ccbedf1a4c 2016-07-06 14:24:25,798 [154] DEBUG Umbraco.Courier.Core.EventManager - [Thread 147] Unloading (count: 1) 2016-07-06 14:24:25,813 [154] ERROR Umbraco.Courier.Core.TaskManager - [Thread 147] Error ExtractionTask with id: 3cb4fc21-8f42-4e18-8073-50648872a167 System.Net.WebException: The request failed with HTTP status 504: Gateway Time-out. at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) at Umbraco.Courier.RepositoryProviders.CourierWebserviceRepositoryProvider.Rollback(String sessionKey) at Umbraco.Courier.Core.Extraction.RevisionExtraction.Extract() at Umbraco.Courier.Core.Tasks.ExtractionTask.Run() at Umbraco.Courier.Core.BackgroundTaskRunner1.ConsumeTaskInternal(T task) 2016-07-06 14:24:25,813 [154] ERROR Umbraco.Courier.Core.BackgroundTaskRunner - [Thread 147] An error occurred consuming task System.Net.WebException: The request failed with HTTP status 504: Gateway Time-out. at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) at Umbraco.Courier.RepositoryProviders.CourierWebserviceRepositoryProvider.Rollback(String sessionKey) at Umbraco.Courier.Core.Extraction.RevisionExtraction.Extract() at Umbraco.Courier.Core.Tasks.ExtractionTask.Run() at Umbraco.Courier.Core.BackgroundTaskRunner1.ConsumeTaskInternal(T task)
Courier Timeout Issue
1.ConsumeTaskInternal(T task) 2016-07-06 14:24:25,813 [154] ERROR Umbraco.Courier.Core.BackgroundTaskRunner - [Thread 147] An error occurred consuming task System.Net.WebException: The request failed with HTTP status 504: Gateway Time-out. at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) at Umbraco.Courier.RepositoryProviders.CourierWebserviceRepositoryProvider.Rollback(String sessionKey) at Umbraco.Courier.Core.Extraction.RevisionExtraction.Extract() at Umbraco.Courier.Core.Tasks.ExtractionTask.Run() at Umbraco.Courier.Core.BackgroundTaskRunner1.ConsumeTaskInternal(T task)is working on a reply...
