I have installed courier on my test and live site which is running on 7.4.3
I have the license in the bin folders
I have added both sites to the courier.config
and when I right click and select courier i get this error
System.Web.Services.Protocols.SoapException: System.Web.Services.Protocols.SoapException: Server was unable to process request. ---> Umbraco.Courier.Core.Exceptions.UnauthorizedClientException: User: Admin could not be authenticated
at Umbraco.Courier.RepositoryProviders.WebserviceProvider.Security.SecurityHelper.ValidateUser(String login, String password)
at Umbraco.Courier.RepositoryProviders.WebserviceProvider.Security.Authentication.AuthorizeClient(String login, String password, Boolean cacheAuthResult)
at Umbraco.Courier.RepositoryProviders.Webservices.Repository.CloseSession(String sessionKey, String username, String password)
--- End of inner exception stack trace ---
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
at Umbraco.Courier.RepositoryProviders.WebServiceProvider.RepositoryWebservice.CloseSession(String sessionKey, String username, String password)
at Umbraco.Courier.RepositoryProviders.CourierWebserviceRepositoryProvider.CloseSession(String sessionKey)
at Umbraco.Courier.RepositoryProviders.CourierWebserviceRepositoryProvider.Dispose(Boolean disposing)
at Umbraco.Courier.RepositoryProviders.CourierWebserviceRepositoryProvider.Dispose()
at Umbraco.Courier.Core.Common.Extensions.GlobalExtensions.DisposeIfDisposable(Object input)
at Umbraco.Courier.Core.Repository.Dispose(Boolean disposing)
at Umbraco.Courier.Core.Repository.Dispose()
at Umbraco.Courier.UI.Dialogs.CommitItem.OnInit(EventArgs e)
at System.Web.UI.Control.InitRecursive(Control namingContainer)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Courier Admin not authenticated
I have the license in the bin folders I have added both sites to the courier.config
Config file
Hi Amalie,
I think that you have hit into an known issue. Try to have a look at this issue http://issues.umbraco.org/issue/COU-104.
There is also a similar thread on the forum, where the workaround that is suggested in http://issues.umbraco.org/issue/COU-104. works.
https://our.umbraco.org/forum/umbraco-pro/courier/60890-Server-was-unable-to-process-request-User-admin-could-not-be-authenticated
Hope this helps,
/Dennis
Thanks Dennis
