  • Simon 2 posts 72 karma points
    Oct 11, 2016 @ 05:07
    Simon
    Courier 2 Dashboard fails to load
    We've recently purchased a licence for Umbraco Courier and are trying to get setup. It works locally, but on our development environment the Courier dashboard fails to load the ascx control.
    The app pool has modify permissions on the Umbraco folder. What else could be causing this?
    Oct 11, 2016 @ 07:22
    Dennis Aaen
    Hi Simon and welcome to our :-)
    Which version of Umbraco and Courier are you using? You are saying that it´s work on your locally, but not on development environment.
    Are you running the same version of Umbraco and Courier on the two environments. Also please make sure that you have this file and folder permissions on the server.
    https://our.umbraco.org/documentation/Getting-Started/Setup/Server-Setup/permissions
    Hope this helps,
    /Dennis
    Oct 11, 2016 @ 22:32
    Simon
    Thanks for the reply Dennis, turns out I was missing the 15 dlls Courier creates when you complete an installation so I've had to check those into source control too.
    Is there a better way to do that? Can I generate those dlls with MSBUILD somehow?
