We're using Umbraco v6.2.1 with Umbraco Courier 2.7.8.9.v6. If we browse to Umbraco -> Courier -> Deploy then we receive the following error:
[KeyNotFoundException: The given key was not present in the dictionary.]
System.Collections.Generic.Dictionary2.get_Item(TKey key) +12264833 Umbraco.Courier.Core.PersistenceManager.get_Default() +76 Umbraco.Courier.Core.ItemProvider.get_DatabasePersistence() +18 Umbraco.Courier.ItemProviders.DataTypeProvider.AvailableSystemItems() +8 Umbraco.Courier.UI.Pages.SimpleRevisionDeploy.<Page_Load>b__0(ItemProvider p) +19 System.Linq.WhereListIterator1.MoveNext() +73 System.Web.UI.WebControls.ListControl.PerformDataBinding(IEnumerable dataSource) +276 System.Web.UI.WebControls.ListControl.OnDataBinding(EventArgs e) +290 System.Web.UI.WebControls.ListControl.PerformSelect() +37 System.Web.UI.WebControls.BaseDataBoundControl.DataBind() +74 Umbraco.Courier.UI.Pages.SimpleRevisionDeploy.Page_Load(Object sender, EventArgs e) +199 System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +51 System.Web.UI.Control.OnLoad(EventArgs e) +95 System.Web.UI.Control.LoadRecursive() +59 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +678
After some decompiling and debugging Courier.UI.dll we found out that the error occurs when binding the data to the dropdownlist.
SimpleRevisionDeploy.cs -> Line: 41, this.ddl_types.DataBind();
protected void Page_Load(object sender, EventArgs e) { if (!this.Page.get_IsPostBack()) { IEnumerable<ItemProvider> enumerable = from p in ItemProviderCollection.Instance.GetProviders() where (bool)((p.AvailableSystemItems().get_Count() > 0) && !CourierSecurity.ValidateNegativeSetting(CourierSecurity.BuildKey(p.Id, UserProviderSettings.DenyUsage))) select p; this.ddl_types.set_DataSource(enumerable); this.ddl_types.set_DataTextField("Name"); this.ddl_types.set_DataValueField("Id"); this.ddl_types.DataBind(); this.ddl_types.Items.Insert(0, new ListItem("Select item type", string.Empty)); } }
Unfortunately it's not possible to Upgrade to Umbraco 7 due to time shortage.
Kind Regards, Frank
Umbraco Courier Key not found
2.get_Item(TKey key) +12264833 Umbraco.Courier.Core.PersistenceManager.get_Default() +76 Umbraco.Courier.Core.ItemProvider.get_DatabasePersistence() +18 Umbraco.Courier.ItemProviders.DataTypeProvider.AvailableSystemItems() +8 Umbraco.Courier.UI.Pages.SimpleRevisionDeploy.<Page_Load>b__0(ItemProvider p) +19 System.Linq.WhereListIterator1.MoveNext() +73 System.Web.UI.WebControls.ListControl.PerformDataBinding(IEnumerable dataSource) +276 System.Web.UI.WebControls.ListControl.OnDataBinding(EventArgs e) +290 System.Web.UI.WebControls.ListControl.PerformSelect() +37 System.Web.UI.WebControls.BaseDataBoundControl.DataBind() +74 Umbraco.Courier.UI.Pages.SimpleRevisionDeploy.Page_Load(Object sender, EventArgs e) +199 System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +51 System.Web.UI.Control.OnLoad(EventArgs e) +95 System.Web.UI.Control.LoadRecursive() +59 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +678After some decompiling and debugging Courier.UI.dll we found out that the error occurs when binding the data to the dropdownlist.
Kind Regards, Frank
