Error Umbraco Courier ("Courier is running in Trial Mode")
Hi Devs,
We are having the following error when trying to transfer contents using Umbraco Courier:
Courier is running in Trial Mode, you can therefore not connect to the repository 'xxx', which is not on this local machine If you need assistance please contact Umbraco via your Umbraco.com profile: http://umbraco.com/profile/options/manage-licenses/license-support.aspx You may also send a request to Umbraco at: support@umbraco.zendesk.com
Typically this error indicates that the licence isn't in the bin directory of the sites.
If it does exist in both, then it might be worth downloading a fresh copy of the licence from the Umbraco site and reapply, just to cover off a possible file corruption issue.
The other possibility is that the sites aren't / weren't defined in the licence ?
The license is in bin directory.
This is what I always do but, I don´t know why after a few days the same error returns.
Hi Devs, We are having the following error when trying to transfer contents using Umbraco Courier:
Does anyone know how to solve this problem?
Note: We have a valid Umbraco Courier license
Best Regards
Hi Vanilson
Hope this helps
Nigel
Hi Nigel,
Sorry for taking too long to give you an answer.
All the sites are defined in the license.
Best regards.
