  • Tausif 4 posts 74 karma points
    Apr 19, 2018 @ 09:00
    Tausif
    Courier connection error
    I have purchased courier, we have two test sites when I try to view my locations I get the error below:
    Cannot connect to the destination https://host//umbraco/plugins/courier/webservices/repository.asmx it failed with status code NotFound
    But if I browse to the repository.asmx file I can view the file.
    There are no redirects, I have tested via localhost and I can connect.
    My two test sites are hosted in Azure App Services.
    Any ideas?
    Apr 27, 2018 @ 11:17
    Tausif
    IPSecurity in web.config was blocking this. Resolved now
  • Stergos 4 posts 75 karma points
    Jul 11, 2018 @ 12:42
    Stergos
    I am having the same issue. I added entries into the ipSecurity settings in web.config to allowUnlisted=true but still the same issue.
    Our azure setup is that the two app services are both deployment slots also if this helps.
  • Nitin Rajwar 25 posts 165 karma points
    Jul 25, 2018 @ 10:48
    Nitin Rajwar
    did you find a solution for this Stergos?
    Jul 26, 2018 @ 22:44
    Stergos
    Not yet. However I have to add ours is giving us a Forbidden error rather than Not Found
