Stack Trace: at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) at System.Web.Services.Protocols.SoapHttpClientProtocol.EndInvoke(IAsyncResult asyncResult) at Umbraco.Courier.RepositoryProviders.WebServiceProvider.RepositoryWebservice.EndGetHashes(IAsyncResult asyncResult) at Umbraco.Courier.RepositoryProviders.CourierWebserviceRepositoryProvider.GetHashes(ItemIdentifier[] itemIds) at Umbraco.Courier.Core.Packaging.RevisionPackaging.GetTargetHashes(IPackagingTarget2 target, IEnumerable1 ids) at Umbraco.Courier.Core.Packaging.RevisionPackaging.PackageBatch() at Umbraco.Courier.Core.Packaging.RevisionPackaging.Package() at Umbraco.Courier.Core.Tasks.PackagingTask.Run() at Umbraco.Courier.Core.BackgroundTaskRunner1.ConsumeTaskInternal(T task) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at Umbraco.Courier.Core.TaskManager.GetSuccessfulProcessedTasks() at Umbraco.Courier.UI.Dialogs.CommitItem.GetTask(String id)
Now I know why it's generating this issue, it's because of the \ at the end of the UDI, my problem is that this error is being thrown before it hits our custom code. So I have no way of handling it.
Has anyone encountered this issue before and can anyone suggest a fix/workaround. I've debugged it locally, but it's not hitting any of my break points.
Apologies, it's been a few months since I did this last and the whole thing was fraught with issues (much like yours) - needless to say it put me right off using Courier.
Anyway, I know it's possible to debug locally - I put our class file in the root ( In a folder called Courier), don't forget to make sure the Build Action for the file is set to compile.
The break point should kick in shortly after it works out what to transfer.
No worries Paul I really appreciate your time. So strange, I'm doing the same - my file is in a root folder called DataResolvers and Build Action is compile. You didnt have any config settings anywhere web or courier config - to register your grid component or resolver?
Oddly, I addded another class using PropertyDataResolverProvider just to see if the type of component was being mistaken - all of a sudden my GridCellResolverProvider class breakpoints started working! Ok, step one complete! LOL, this'll be a long one.
Problem transferring content - error thrown
Hopefully someone can help me. We have a custom GridCellResolverProvider. When we attempt to deploy a page, we get an error:-
Exception Message: Server was unable to process request. ---> String "umb://media/3d89c8210dae45ae83c6f65e700fd6d4\" is not a valid udi.
Exception Type: System.Web.Services.Protocols.SoapException
1 ids) at Umbraco.Courier.Core.Packaging.RevisionPackaging.PackageBatch() at Umbraco.Courier.Core.Packaging.RevisionPackaging.Package() at Umbraco.Courier.Core.Tasks.PackagingTask.Run() at Umbraco.Courier.Core.BackgroundTaskRunner1.ConsumeTaskInternal(T task) --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at Umbraco.Courier.Core.TaskManager.GetSuccessfulProcessedTasks() at Umbraco.Courier.UI.Dialogs.CommitItem.GetTask(String id)Now I know why it's generating this issue, it's because of the \ at the end of the UDI, my problem is that this error is being thrown before it hits our custom code. So I have no way of handling it.
Paul
Hi Paul
Did you solve this issue? Can you share with our community how to do it?
Alex
Hi Alex, I did. I ended up using a regular expressions to sort it.
This seems to have done the trick.
Hope it helps someone else.
Paul
Of course, it will help. Paul, thanks for sharing, have a great day!
Hi Paul, Im creating a custom resolver and unable to hit any breakpoints within the class. Any tips on creating my first grid resolver?
I created the class, compiled to site, attached to correct w3 process and no methods ever get hit. Sample class:
Hi Mike,
So do you have two localhost sites running at the same time?
Thanks Paul
Sure do: one for editing and publishing and one for delivery
I'm not being much help sorry.
Thanks again!
Good luck (you'll need it :) ). If you need any parser code to pull out links to internal pages/media let me know.
