  • Matt Barlow | jacker.io 164 posts 740 karma points c-trib
    Jul 02, 2018 @ 13:10
    How to deploy Umbraco Forms using Courier?
    Hey,
    Here are the various versions I am using:
    • Umbraco 7.7.4
    • Umbraco Forms 6.0.8
    • Umbraco Courier 3.1.6
    Does Courier support deployment of Umbraco Forms out of the box? I am trying to work out the best way to configure courier to deploy Umbraco Forms.
    When I courier my content that has a form included via a form picker. That form is not included when it's couriered across.
    Courier not deploying Umbraco Forms
    I found this link, https://github.com/umbraco/Umbraco.Courier.FormsProvider
    Which seems to do what I want, so I install both providers via nuget:
    Then I get a button next to each form, allowing it to be couriered:
    But then this doesn't work:
    Any help would be appreciated.. thanks in advance.
    • M
    Jul 19, 2018 @ 14:24
    Surely I can't be the only one that wants to know how to do this? :D
  • Tom DF 3 posts 73 karma points
    Jul 26, 2018 @ 01:06
    Tom DF
    Yea I'd like to know how people are deploying forms... or are you all making them on every environment.....
  • Kevin Meilander 82 posts 408 karma points c-trib
    Jul 26, 2018 @ 13:23
    Kevin Meilander
    Are you able to make a courier revision with the form in it, rather than right clicking the form? That's generally how we've couriered forms.
    Although for most of our sites, we usually keep the forms data files with the code and move around that way. Or sometimes just manually.
  • Yakov Lebski 594 posts 2350 karma points
    Aug 31, 2018 @ 07:10
    Yakov Lebski
    I think you should install Umbraco.Courier.FormsProvider on destination server too
