Is there a way of ensuring that the Culture and Hostnames settings do not get couriered from one environment to another?
We have an issue that, when Couriering home nodes from staging to live, Courier is adding the staging mappings to the live Culture and Hostnames settings. It doesn't overwrite, it appends.
Umbraco version is 7.10.5
Courier version is 3.1.6
the solution is SiteDomainHelper, you should define both domains on staging and live environment. Your live environment is a copy of your staging, you shouldn't modify it.
Courier with Culture and Hostnames
Umbraco version is 7.10.5 Courier version is 3.1.6
Thanks in Advance
Steve
Hi, the solution is SiteDomainHelper, you should define both domains on staging and live environment. Your live environment is a copy of your staging, you shouldn't modify it.
In startup, OnApplicationStarting
In this situation, Umbraco will show only domain that appears in each group
