We have a complex Umbraco setup and we deploy new changes on a regular basis. Recently we noticed that Umbraco Contour menu at the backend is broken and it will not load the list of forms created previously. When we removed and re-installed Contour in our development environment it resolved the issue, but we lost all previously created forms, pre value sources and entries.
What is the best way to resolve the Contour issue so that I do not loose any previously created data.
Umbraco Version: v7.2.6
Contour Version: 3.0.21
The error is:
No provider with id '8786bdad-fe7e-4868-8d65-599f1ac3e24c' found
Exception Details: Umbraco.Forms.Core.Common.ProviderException: No provider with id '8786bdad-fe7e-4868-8d65-599f1ac3e24c' found
Source Error:
Stack Trace:
[ProviderException: No provider with id '8786bdad-fe7e-4868-8d65-599f1ac3e24c' found]
Umbraco.Core.Cache.HttpRuntimeCacheProvider.GetCacheItem(String cacheKey, Func`1 getCacheItem, Nullable`1 timeout, Boolean isSliding, CacheItemPriority priority, CacheItemRemovedCallback removedCallback, CacheDependency dependency) +1056
Umbraco.Core.CacheHelper.GetCacheItem(String cacheKey, CacheItemPriority priority, CacheItemRemovedCallback refreshAction, CacheDependency cacheDependency, TimeSpan timeout, Func`1 getCacheItem) +491
umbraco.cms.businesslogic.cache.Cache.GetCacheItem(String cacheKey, Object syncLock, CacheItemPriority priority, CacheItemRemovedCallback refreshAction, CacheDependency cacheDependency, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem) +275
Umbraco.Forms.Data.Storage.FormStorage.GetAllForms(Boolean archived) +463
Umbraco.Forms.UI.Dashboard.FormsDashboard.Page_Load(Object sender, EventArgs e) +1295
System.Web.UI.Control.OnLoad(EventArgs e) +109
System.Web.UI.Control.LoadRecursive() +68
System.Web.UI.Control.LoadRecursive() +165
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +4498
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.6.118.0
Umbraco Contour: No provider with id 'GUID' found
The error is:
