  • Sebastian Dammark 583 posts 1407 karma points
    Apr 04, 2016 @ 07:57
    Sebastian Dammark
    Changing the upload path in Forms, when using UmbracoFileSystemProviders.Azure ?
    Is it possible to change the upload path for Forms ?
    My problem is that I'm using UmbracoFileSystemProviders.Azure to all ,y media files. But that doesn't play nicely with Forms who apparently dumps the files "locally" and not in the Azure cloud.
    So when I try to access the files uploaded through forms in "/media/forms", I get a 404 since my Azure cloud container is named "media"
    So my thoughts are to change the upload path for forms, if it's possible ? Or are there other solutions to my problem ?
    Thanx in advance
  • Dennis Adolfi 1082 posts 6450 karma points MVP 6x c-trib
    Apr 04, 2016 @ 08:23
    Dennis Adolfi
    Hi Sebastian.
    In Umbraco Forms config file, (App_Plugins/UmbracoForms.config) there is a config for UploadStorageDirectory. However, this seems to be a issue with Forms not minding this config. Se link: http://issues.umbraco.org/issue/CON-797.
    I tried this config but it still does´nt work. Maybe you should upvote this issue so it get priority.
    However you seem to be able to set the upload directory programmatically. What i did is i created a ApplicationStartupEvent and set the directory this way and this works:
    public class ApplicationStartup : ApplicationEventHandler
            protected override void ApplicationStarted(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
                // Set Umbraco Forms Upload Directory programmatically.
                Umbraco.Forms.Core.Configuration.UploadPath = "/CustomFolder";
    Hope this helps you!
    Apr 04, 2016 @ 10:56
    Dennis Adolfi
    Saw that you upvoted the issue and commented on http://issues.umbraco.org/issue/CON-797, great! :)
    Did you try the ApplicationStartup soultion? Interested if this works for you on Azure. (I dont have a Azure account to try with and it might be good for others to know if it works.)
