  • Adriano Fabri 469 posts 1633 karma points
    May 16, 2016 @ 15:17
    Adriano Fabri
    How to display poll results with Umbraco Forms (Contour) on Umbraco 7
    Hi to all, before buy it I'm try to test Umbraco Forms (Contour) package to display forms and polls.
    The forms function properly, but I have a problem with polls.
    I already created the poll and I put it in my homepage. When I send my vote, it correctly save it and I can see my vote in the backend.
    Now...I need to create a page where I can display poll results, but my partial view not function. I didn't found any documentation about display results.
    Can anyone tell me how to display the poll results (in % or graphic)?
    Thank you for the support Adriano
    May 20, 2016 @ 08:03
    Adriano Fabri
    SOLVED!!!
    May 20, 2016 @ 13:51
    Hi Adriano
    Ace that you found a way to solve this issue - Do you mind sharing how you solved it? Others might benefit from it in the future should they have the same scenario as you :)
    Happy coding!
