  • Nathan Sleigh 109 posts 353 karma points
    Jun 28, 2016 @ 09:26
    Nathan Sleigh
    Umbraco Forms Datepicker Issue
    Hi Guys,
    Im having an issue with the umbraco forms date-picker.
    I have inserted the date-picker onto a page, but for some reason it thinks its an email field.
    Am I missing something when setting the form up or is there a wider issue with it?
    Nathan
  • Warren Buckley 2106 posts 4836 karma points MVP 7x admin c-trib
    Jul 08, 2016 @ 10:46
    Warren Buckley
    Hi Nathan,
    This is an unusual error but as the underlying HTML input type currently is a textbox. Chrome autocomplete for some reason thinks this is an email field and suggesting that to you.
    Eventually this will be a proper HTML5 date field.
    You could modify the HTML views for the fields or override it for a specific form & field to ensure you add the HTML attribute autocomplete to disable it off the top of my head.
    Warren
  • Jay 425 posts 652 karma points
    Jul 22, 2016 @ 11:05
    Jay
    Hey warren,
    How do i disable the popup option to not show DatePicker for time being? Can't find out where to comment that out.
    Thanks!
    Jul 22, 2016 @ 20:54
    Warren Buckley
    Hi Nathan,
    You cannot disable built in Umbraco Forms Field Type providers currently.
    If this is something you want to see, then please add it as a feature request on the issue tracker here - http://issues.umbraco.org/issues/CON
    Warren
