I have a custom member property called "Number" which I add to a form in a hiddenfield by using {member.number}. All appear to be working fine.
However, something is not right as formsubmissions frequently gets the wrong property. Usually the error occurs when:
The errors always appear in sequence of first correct, following one or more erronous (same as first submission). This behavior then repeats.
Is there perhaps some caching issue?
Wierd error on when using DefaultValue on member data
