  • Matthew Jarvis 6 posts 38 karma points
    Oct 31, 2016 @ 16:25
    Matthew Jarvis
    Forms not rendering through RTE
    I've searched through and seen a lot of threads about the above but haven't found one that answers my issue.
    Running Umbraco 6.1.4 and Contour 3.0.2.1
    My issue...
    I cannot get Contour to display when i use the 'Insert form' or 'Insert form via UserControl' in the RTE.
    I can only get a Contour form to display if i insert macro directly into a template (which is not a suitable solution as don't want every page using that template to inherit the form).
    I have a form runat="server" ` tag already on my masterpage which runs from the opening to the closing tag as some other elements on my page require to runat"server".
    I am currently outputting my 'body' content via a Macro using XSLT (XSLT basically runs some scripts that check language chosen by user and then displays selected language).
    I have tried to wrap a
    tags around my content in the template but still doesn't render. Have tried to run a second form runat="server" ` but get the standard asp error message "Cannot have more than one server form tag"
    Long story short -
    • Does contour try to add it's own Form Tags which might interfere with the form runat="server" ` i already have in my masterpage?
    • If so - is there a way to try and stop it adding its own form tag?
      Any help is much appreciated. Many thanks
    Matt
  • Alex Skrypnyk 6112 posts 23606 karma points MVP 7x admin c-trib
    Nov 14, 2016 @ 18:04
    Alex Skrypnyk
    Hi Matt,
    Did you fix this issue?
    We have similar problem.
    Alex
    Nov 16, 2016 @ 12:48
    Matthew Jarvis
    Hi Alex,
    Have not fixed, neither have I received any answers to my question :-)
