  • Heather Floyd 610 posts 1032 karma points MVP 6x c-trib
    Nov 08, 2016 @ 19:46
    Heather Floyd
    Custom FieldType in Umbraco Forms : Setting properties always NULL
    I have created a custom fieldtype for Umbraco Forms based on the FileUpload fieldtype which will place the uploaded item into the Media section, so it can be automatically linked to a content node created by the submitted form data.
    I have defined some settings, which I can see in the Umbraco Forms editor, but in my code file, the properties are always NULL.
    If I debug and look at "this.Settings()" - I see the custom Settings listed.
    Is my configuration incorrect?
    Simplified code:
    namespace MySite.Forms.FieldTypes
        using System;
        using System.IO;
        using System.Drawing;
        using System.Linq;
        using System.Web;
        using Umbraco.Core;
        using Umbraco.Core.Models;
        using Umbraco.Core.IO;
        using Umbraco.Core.Logging;
        using Umbraco.Forms.Core;
        using Umbraco.Web;
        public class MediaUpload : Umbraco.Forms.Core.Providers.FieldTypes.FileUpload
            const int ImageMediaTypeId = 1032;
            [Umbraco.Forms.Core.Attributes.Setting("Allowed file extensions",
                 description = "Allowed file extensions (CSV)",
                 alias = "AllowedExtensions")]
            public string AllowedExtensions { get; set; }
            [Umbraco.Forms.Core.Attributes.Setting("Media Parent ID",
                 description = "ID of the parent where the media will be saved",
                 alias = "MediaParentId")]
            public string MediaParentId { get; set; }
            public MediaUpload()
                //Provider
                this.Id = new Guid("84f24c36-103d-4161-b2ec-058e57e315f2");
                this.Name = "Media Upload";
                this.Description = "Upload file to Umbraco Media Section";
                //FieldType
                this.Icon = "icon-cloud-upload";
                this.DataType = FieldDataType.Integer;
                var settings = this.Settings(); //<---This shows the settings when checked...
                var test = settings.Count;
            public override IEnumerable<object> ProcessSubmittedValue(Umbraco.Forms.Core.Field AssociatedField, System.Collections.Generic.IEnumerable<object> Values, System.Web.HttpContextBase HttpContext)
                List<Object> vals = new List<object>();
                var parentId = this.MediaParentId; //<--- This is always NULL
                // Do stuff with submitted file...
                return vals;
            public override IEnumerable<object> ConvertToRecord(Field field, IEnumerable<object> postedValues, HttpContextBase context)
                //Do Stuff
                return vals;
    Thanks! ~Heather
