  • Tom Madden 253 posts 455 karma points MVP 4x c-trib
    Dec 08, 2016 @ 17:20
    Tom Madden
    Problems with custom workflows since upgrade to Forms 4.4?
    just wondering if anyone else has problems with custom workflows when working with Forms 4.4? (in Umbraco 7.5.4)
    I'm getting a 500 error when trying to save the workflow and this url is called
    /umbraco/backoffice/UmbracoForms/Workflow/ValidateWorkflowSettings
    This happens in a project with Forms 4.4 but the same custom workflow works with Forms version 4.3.2 in another recent project.
    thanks t
    Dec 08, 2016 @ 17:28
    Tom Madden
    In case this helps, this is what my request payload looks in raw format:
    {"id":"00000000-0000-0000-0000-000000000000","name":"MAilChimp Subscribe","form":"00000000-0000-0000-0000-000000000000","active":true,"isDeleted":false,"sortOrder":-1,"workflowTypeId":"b457fb0c-728e-4ac5-9c31-42819b7e794c","workflowTypeName":"D8 MailChimp Subscribe","workflowTypeDescription":"This will subscribe the form data to MailChimp","workflowTypeIcon":null,"workflowTypeGroup":null,"settings":[{"name":"List Id","alias":"ListId","description":"MailChimp List Id","prevalues":[""],"view":"/AppPlugins/UmbracoForms/Backoffice/Common/SettingTypes/TextField.html","value":"8d7a31e23f"},{"name":"Send Welcome Email","alias":"SendWelcomeEmail","description":"Enable or disable MailChimp welcome email","prevalues":[""],"view":"/AppPlugins/UmbracoForms/Backoffice/Common/SettingTypes/CheckBox.html","value":"False"}]}
    Haven't compared the same payload in 4.3.2 forms (yet)
    t
    Dec 08, 2016 @ 17:30
    Tom Madden
    OK here's the request payload in Forms 4.3.2
    {"id":"0d1f6405-1735-40c2-969e-e3ff10c5546a","name":"Subscribe to MAilChimp","form":"0628292a-3a6c-41e6-ad91-8c2a68c75bbc","active":true,"isDeleted":false,"sortOrder":1,"workflowTypeId":"b457fb0c-728e-4ac5-9c31-42819b7e794c","workflowTypeName":"D8 MailChimp Subscribe","workflowTypeDescription":"This will subscribe the form data to MailChimp","workflowTypeIcon":null,"workflowTypeGroup":null,"settings":[{"name":"List Id","alias":"ListId","description":"MailChimp List Id","prevalues":[""],"view":"/AppPlugins/UmbracoForms/Backoffice/Common/SettingTypes/TextField.html","value":"7a8f09f17a"},{"name":"Send Welcome Email","alias":"SendWelcomeEmail","description":"Enable or disable MailChimp welcome email","prevalues":[""],"view":"/AppPlugins/UmbracoForms/Backoffice/Common/SettingTypes/CheckBox.html","value":null}]}
    I'd suspect the odd guids as the cause of the issue
    t
  • Magere 2 posts 71 karma points
    Dec 08, 2016 @ 19:55
    Magere
    so have you found anything that helps?
    Dec 09, 2016 @ 10:07
    Tom Madden
    I've not, but I believe Warren will be having a look at this. I'll update here if he doesn't.
    Did you experience the same issues? It would be goo to know it's not just me.
    t
    Dec 12, 2016 @ 13:47
    Tom Madden
    In case anyone hits this, it turns out to be an issue with bool settings in a custom workflow causing an Exception in ValidateSettings(). Change your setting to be a string and check for "True" or "False" to check the value.
    Thanks to Warren for helping point me in the right direction (and suggesting the workaround).
    I will post this to the issue tracker when I get a minute (in the next day at least)
    t
  • Marc Stöcker 104 posts 560 karma points c-trib
    Mar 02, 2017 @ 11:42
    Marc Stöcker
    Did you ever log an issue, Tom? Unfortunately I couldn't find it amongst these: http://issues.umbraco.org/issues?q=forms+bool
    I'm wondering because this bug seems to still be occuring with 4.4.2 (current version). Have you experienced that as well?
    Thanks!
  • Thanh Pham 23 posts 140 karma points
    Dec 13, 2016 @ 06:38
    Thanh Pham
    Hi Tom,
    I think I have the same issue when I upgraded UmbracoCMS to latest version 7.5.6 and UmbracoForms to version 4.4.0
    When I tried to create a form, as soon as I hit Save, I got the error as shown below. I then refresh the page and realised that the Form was created but without a workflow attached.
    Can you please tell me exactly the steps how to fix your issue?
    Here is the Request Payload in case it can help investigate: enter image description here
    Dec 13, 2016 @ 09:08
    Tom Madden
    Hi Than,
    I think these are different issues. Mine happened when I hit the Submit button to add a custom workflow, not when saving the form, and I didn't get an error reported back from the CMS.
    My problem was down to a boolean settings in my workflow which Forms didn't like, so I got round it by changing my setting to a TextField and checking for the values "True" or "False".
    Can you save your form without a custom workflow okay?
    HTH
    t
    Dec 14, 2016 @ 04:11
    Thanh Pham
    Hi Tom,
    I tried to clean up the Bin folder and compiled the whole project again and now got new error messgage regarding the IPayloadCacheRefresher every time I tried to save a form, see below. No ideas what it is now :(. Anyone could shed a light on this matter please!
    Note: I don't install any package Umbraco Forms Cache Refresher or whatever its called. I also attached my current installed package if it can help investigate.
    Mar 14, 2017 @ 13:29
    Marc Stöcker
    Just to let everybody know, I have logged an issue a few days ago: http://issues.umbraco.org/issue/CON-1277
