  • Derek Ainslie 1 post 71 karma points
    Dec 19, 2016 @ 11:18
    Derek Ainslie
    Umbraco Forms 4.4 Static Values not saving
    I upgraded Umbraco Forms from 4.3 to 4.4 last week on Umbraco v7.5.4 and since then the 'Save as Umbraco content node' static values no longer appear in their respective fields. However when I check the workflow json I can still see the values, they just no longer appear in the mapped field list in the CMS.
    I tried a test "clean" installation of latest Umbraco and latest Umbraco Forms with one of the demo sites and the same thing happens there. In fact I also have the 'static value field boxes not aligned' problem that I think has been raised elsewhere.
    Any help appreciated!
    Dec 20, 2016 @ 11:39
    Dennis Aaen
    Hi Derek,
    Could you please report your findings here for the Umbraco Forms 4.4.0 that should be ace http://issues.umbraco.org/issues/CON so it can be fixed in a later release of Umbraco Forms.
    /Dennis
