I created a Prevalue source in the Umbraco Forms section of the backoffice. If I am selecting "umbracoDbDSN" as option from "Connection String from web.config", then why do I also need to fill in a value for "Connection String"? I would think if umbracoDbDSN was selected it would just use that connection string from the web.config file? This seems a little counter productive, because now when I move the site to different environments I need to manually change the connection string each time. Am I missing something?
Prevalue Sources - Connection String
Lee
Hi Lee,
Did issue fixed?
I'm facing this issue now.
Regards, Kowshik
