  • LH 4 posts 74 karma points
    Jan 19, 2017 @ 06:34
    LH
    Campaign Monitor integration
    Hi all,
    I have been trying to integrate Umbraco Forms to Campaign Monitor, following this post: https://www.liquidint.com/blog/extending-umbraco-contour-campaign-monitor-integration/
    It turns out that the approach no longer work for Umbraco Forms since I could not render custom FieldSettingType as well as unable to set prevalues of FieldPreValueSourceType dynamically.
    Any idea for integrating new Umbraco Forms to Campaign Monitor would be very appreciated.
    Thanks a lot in advanced.
    Linh
  • Simon Eldevig 29 posts 190 karma points
    Sep 01, 2017 @ 10:44
    Simon Eldevig
    Hi Linh,
    I've been struggling with the same problem where I found an updated article about the Campaign Monitor integration from 2014: http://richardterris.blogspot.dk/2014/11/umbraco-contour-campaign-monitor.html
    I haven't tried it, but maybe you can use it.
    I solved this issue by posting the form to a Zapier webhook where I could handle the data and then create a subscriber in Campaign Monitor based on data from the formular.
    This is a very easy integration although you will have to pay 20$ a month for a Zapier account, but I think it's worth checking out! :-)
    You can see my Zapier recipe here:enter image description here
