I would like to populate my Drop Down control on the Umbraco Form by using an external webservice.
Does anyone know what I need to add to the Fields in the Datasource section of the CMS to get this working (/umbraco/#/forms/datasource/edit/-1?create)?
At the moment Im getting an error when I save it:
Datasource failed to save: Data at the root level is invalid. Line 1, position 1.
And what do I need to return? XML or JSON? At the moment Im returning JSON.
Connect to a Webservice when using Forms
At the moment Im getting an error when I save it: Datasource failed to save: Data at the root level is invalid. Line 1, position 1.
Any ideas?
Thanks in advance, Jon
Umbraco Forms is so poorly supported / documented. I can't figure out how to do this either.
