  • Simeon Ostberg 123 posts 389 karma points
    Mar 31, 2017 @ 14:43
    Simeon Ostberg
    Radiobutton and Checkbox not showing on page
    I'm testing Umbraco Forms in trial mode. Unfortunately button or checkbox are visible in the forms builder, but not on the page. They are just not showing up.
    Is there a chance to change this?
    Thanks a lot!
    Best, Simeon
  • Alex Skrypnyk 6179 posts 24240 karma points MVP 8x admin c-trib
    Apr 02, 2017 @ 15:38
    Alex Skrypnyk
    Hi Simeon
    Do you have some errros in log?
    If you look at source code of the page, is there a radiobutton?
    Alex
    Apr 03, 2017 @ 07:58
    Simeon Ostberg
    Hi Alex,
    I have a warning for an unknown path to TraceLogViewer (which I already uninstalled)?! But none from forms.
    Yes, the code has a checkbox and radiobuttons. Even if I click next to the "Yes" or "No" field, the conditions for the following fields work - I just don't see the symbol.
    Thanks, Simeon
    Apr 03, 2017 @ 11:39
    Simeon Ostberg
    Update: I tried several browsers:
    • Chrome 56 and 57 Desktop and Mobile: Not visible
    • Edge 38 Desktop: Not visible
    • Firefox 52 Desktop and Mobile: Visible
    • Safari 5.0.5 Desktop: Not visible
    Obviously radio buttons and checkbox only show up on a Firefox browser, although the code always includes them.
    Apr 04, 2017 @ 11:25
    Simeon Ostberg
    Next update - and solution:
    I googled "Chrome Radio Buttons not showing", coming up on this site: http://stackoverflow.com/questions/35618144/radio-button-is-not-showing-in-safari-and-chrome
    After disabling the line "-webkit-appearance: none;" in the CSS it works...
    Apr 04, 2017 @ 11:59
    Alex Skrypnyk
    Just wanted to write that this is might be a CSS problem, because different browsers show different results.
    Glad that topic is solved.
    Have a nice day.
    /Alex
    Apr 05, 2017 @ 07:01
    Simeon Ostberg
    Hi Alex,
    Yes, it seems to be a CSS issue.
    Thanks, Simeon
