  • Christian Lyck 16 posts 98 karma points
    Apr 02, 2017 @ 16:11
    Christian Lyck
    Package section does not work after deploy to Azure
    Hi How to Web deploy to Azure ?
    I deployet my Umbraco website to Azure using Web Deploy.
    The site runs fine except all that concerns the packages. I can not install or uninstall packages. Forms package does not works either.
    Anybody know what I'm doing wrong.
    Best Regards Christian Lyck.
    Apr 02, 2017 @ 16:28
    Alex Skrypnyk
    Hi Christian,
    Can you check App_Plugins folder, does it have the same files as your locall installation?
    Also look logs, maybe there are some errors.
    Alex
    Apr 02, 2017 @ 20:37
    Christian Lyck
    Hi Alex
    Thanks. I could not find any documentation on whether to include App_Plugins folder in the project. I have tried now, but it has not helped the same problem.
    I have not figured out how to view files deployet to Azure.
    How does I see the log when I can not install a log view package.
    Best regards Christian Lyck
    Sorry I can see the files via FTP and they are not the same.
    I think it is a database problem, maybe when I export from local to Azure.
    Database exception occurred System.Data.SqlClient.SqlException (0x80131904): Cannot insert the value NULL into column 'id', table '[DateBase].dbo.umbracoLog'; column does not allow nulls. INSERT fails.
    Apr 02, 2017 @ 22:34
    Alex Skrypnyk
    Hi Christian
    Log files are in "/App_Data/Logs" folder, you can see it via a file system. or just install this package - https://our.umbraco.org/projects/developer-tools/diplo-trace-log-viewer/ and you will able to see logs in admin section.
    Alex
