No connection could be made because the target machine actively refused it 127.0.0.1:25
I am trying to set up SMTP for a client of mine's Umbraco 7.7 website.
The forms were built using the UmbracoForms plugin and everything seems to be fine on that side of things. The workflow is created and set to send the email to my email address.
I'm running the website localhost and I do not have a license. (I've read that you can run localhost if you do not have a license.
Please correct me if i'm wrong)
I went into the web.config and added the client's SMTP settings and the form did not appear to send.
I went into the Log files and saw that I am receiving this error:
*System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 127.0.0.1:25*
I then tried to switch over to our personal SMTP credentials that I am 100% sure work, and I am receiving the same error.
I cannot even receive an email from the "Forgot your Password" link on the login page.
I checked our mailgun logs, and it looks like it never even made it there.
Here are the SMTP credentials that I added to the web.config:
I even added my from email to the umbracoSettings.config file like this:
<notifications>
<!-- the email that should be used as from mail when umbraco sends a notification -->
<email>[email protected]</email>
</notifications>
Here is the full error that I am receiving in the log file.
2017-10-24 16:27:35,135 [P16856/D4/T45] ERROR Umbraco.Forms.Core.Providers.WorkflowTypes.SendRazorEmail - There was a problem sending a Razor email to '[email protected]' from Workflow for Form 'Contact Form' with id '0f36c378-bf45-44b2-8ce3-fcd4057b2a3a' for Record with unique id '03715450-5edd-4b5b-8443-ee16600b9db0'
System.Net.Mail.SmtpException: Failure sending mail. ---> System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 127.0.0.1:25
at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
--- End of inner exception stack trace ---
at System.Net.ServicePoint.GetConnection(PooledStream PooledStream, Object owner, Boolean async, IPAddress& address, Socket& abortSocket, Socket& abortSocket6)
at System.Net.PooledStream.Activate(Object owningObject, Boolean async, GeneralAsyncDelegate asyncCallback)
at System.Net.PooledStream.Activate(Object owningObject, GeneralAsyncDelegate asyncCallback)
at System.Net.ConnectionPool.GetConnection(Object owningObject, GeneralAsyncDelegate asyncCallback, Int32 creationTimeout)
at System.Net.Mail.SmtpConnection.GetConnection(ServicePoint servicePoint)
at System.Net.Mail.SmtpTransport.GetConnection(ServicePoint servicePoint)
at System.Net.Mail.SmtpClient.GetConnection()
at System.Net.Mail.SmtpClient.Send(MailMessage message)
at Umbraco.Forms.Core.Providers.WorkflowTypes.SendRazorEmail.Execute(Record record, RecordEventArgs e)
On the second line of the message in your logfile, it reads ‘127.0.0.1:25’. That means you’re still trying on localhost (which is 127.0.0.1). Probably you haven’t saved the web.config file after changing it... Or you have to restart your local application.
By the way: I got the same error message when trying to connect to the SendGrid smtp service (smtp.sendgrid.net). This appeared to be a problem with using port 25: despite their documentation only port 587 could be used.
Hth
I'm running the website localhost and I do not have a license. (I've read that you can run localhost if you do not have a license. Please correct me if i'm wrong)
Any guidance would be greatly appreciated!
Thank You
On the second line of the message in your logfile, it reads ‘127.0.0.1:25’. That means you’re still trying on localhost (which is 127.0.0.1). Probably you haven’t saved the web.config file after changing it... Or you have to restart your local application. By the way: I got the same error message when trying to connect to the SendGrid smtp service (smtp.sendgrid.net). This appeared to be a problem with using port 25: despite their documentation only port 587 could be used. Hth
