  • EJS 6 posts 89 karma points
    Oct 28, 2017 @ 15:57
    EJS
    Recaptcha with multi step form should not validate on 'Next' step
    Just started using the reCAPTCHA plugin by Alex Skrypnyk. Works great, except when using the reCAPTCHA on a multi step (multipage) form.
    Usually, the reCAPTCHA field will be used on the last page of the form. However, when clicking next, the FormValidate event is triggered, and the reCAPTCHA is always checked.
    The reCAPTCHA field should only be checked if the reCAPTCHA field is on the current form page. I'm not sure though this info is available via the FormValidationEventArgs...?
    Cheers, EJ
    Oct 28, 2017 @ 20:57
    Alex Skrypnyk
    Hi EJS
    I will have a look on this problem, thanks for submitting the issue.
    ALex
  • Jeffrey Schoemaker 408 posts 2138 karma points MVP 8x c-trib
    Oct 31, 2017 @ 07:31
    Jeffrey Schoemaker
    Hi Alex,
    we've got a piece of code by Matt Barlow for our Forms-on-Steroids-package (https://our.umbraco.org/projects/backoffice-extensions/umbraco-forms-on-perplex-steroids/) that also includes a ReCaptcha that solves this specific issue.
    It will probably give some inspiration for your fix too (https://our.umbraco.org/projects/backoffice-extensions/umbraco-forms-on-perplex-steroids/feedback-bugs/87162-recaptchav2-on-forms-with-multiple-pages-cant-navigate-between-form-pages).
    Cheerio,
    Jeffrey
  • ECL 7 posts 37 karma points
    May 10, 2018 @ 12:14
    ECL
    I am having this issue on a multi-page form:
    Umbraco Forms 6.0.6
    Umbraco version 7.7.8 assembly: 1.0.6582.14881
    Works OK on page 1 - when applied to the last page, I get the following error when I try to progress form Page 1
    The operation has timed out
    Exception Details: System.Net.WebException: The operation has timed out
    Source Error:
    Stack Trace:
    [WebException: The operation has timed out]
       System.Net.WebClient.DownloadDataInternal(Uri address, WebRequest& request) +365
       System.Net.WebClient.DownloadString(Uri address) +111
       PerplexUmbraco.Forms.Code.UmbracoEvents.RecaptchaValidate(Object sender, FormValidationEventArgs e) +572
       Umbraco.Forms.Web.Controllers.UmbracoFormsController.ValidateFormState(FormViewModel model, Form form, HttpContextBase context, Boolean captchaIsValid) +1719
       Umbraco.Forms.Web.Controllers.UmbracoFormsController.HandleForm(FormViewModel model, Boolean captchaIsValid) +348
       lambda_method(Closure , ControllerBase , Object[] ) +195
       System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters) +209
       System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters) +35
       System.Web.Mvc.Async.AsyncControllerActionInvoker.<BeginInvokeSynchronousActionMethod>b__39(IAsyncResult asyncResult, ActionInvocation innerInvokeState) +39
       System.Web.Mvc.Async.WrappedAsyncResult`2.CallEndDelegate(IAsyncResult asyncResult) +67
       System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethod(IAsyncResult asyncResult) +42
       System.Web.Mvc.Async.AsyncInvocationWithFilters.<InvokeActionMethodFilterAsynchronouslyRecursive>b__3d() +72
       System.Web.Mvc.Async.<>c__DisplayClass46.<InvokeActionMethodFilterAsynchronouslyRecursive>b__3f() +385
       System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethodWithFilters(IAsyncResult asyncResult) +42
       System.Web.Mvc.Async.<>c__DisplayClass2b.<BeginInvokeAction>b__1c() +30
       System.Web.Mvc.Async.<>c__DisplayClass21.<BeginInvokeAction>b__1e(IAsyncResult asyncResult) +185
       System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult) +38
       System.Web.Mvc.Controller.<BeginExecuteCore>b__1d(IAsyncResult asyncResult, ExecuteCoreState innerState) +29
       System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +65
       System.Web.Mvc.Controller.EndExecuteCore(IAsyncResult asyncResult) +52
       System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +36
       System.Web.Mvc.Controller.EndExecute(IAsyncResult asyncResult) +38
       System.Web.Mvc.MvcHandler.<BeginProcessRequest>b__5(IAsyncResult asyncResult, ProcessRequestState innerState) +43
       System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult) +38
       System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +393
       System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step) +195
       System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +12
