  • Christian A 24 posts 98 karma points c-trib
    Dec 05, 2017 @ 15:30
    Christian A
    2
    Prevalue Source - SQL Database - Connection String from web.config
    The "SQL Database" option for Prevalue Sources has two fields for connections, one just called "Connection String" and another one called "Connection String from web.config".
    For some reason, that is not obvious to me, both of them have to be filled out and it seems to always default to the "Connection String" and never use the "Connection String from web.config".
    What is the logic behind this if any?
  • lori ryan 239 posts 573 karma points
    May 31, 2018 @ 13:39
    lori ryan
    Hi Christian Having a similar problem myself - would rather not have the connection string in plain text within the cms but pull it from the web.config have you found a way around this?
    May 31, 2018 @ 16:05
    Christian A
    Unfortunately no, this piece of functionality never seems to have been implemented correctly in Umbraco.
  • jake williamson 205 posts 849 karma points
    Sep 10, 2019 @ 05:30
    jake williamson
    hey there,
    just found this thread after trying to get a sql database prevalue source working...
    having to enter the connection string rather than selecting it from the web.config is fairly major security issue!
    i'm searching on https://github.com/umbraco/Umbraco.Forms.Issues/issues but not seeing anything reported...
    it might not've been fixed yet as they don't know about it?! assuming i'm looking in the right place that is...
    Sep 10, 2019 @ 13:26
    Christian A
    I don't think it has ever been fixed / implemented.
    Sep 10, 2019 @ 23:54
    jake williamson
    i've chucked it in as an issue:
    https://github.com/umbraco/Umbraco.Forms.Issues/issues/223
    just started using the sql database prevalue source in a project. it works really well but having the raw connection string showing in the backoffice is far from ideal...
    fingers crossed it'll be an easy one for them to sort!
    Sep 12, 2019 @ 11:39
    Christian A
    Agreed. And they started updating forms again, so lets cross our fingers.
