  • Stief Dirckx 43 posts 76 karma points
    Jan 10, 2018 @ 15:22
    Stief Dirckx
    Using magic strings
    I configured a workflow to save a content node when a form is submitted. For a few document properties I used 'magic strings' to give them a value.
    • {record.IP} to get the IP address of the website visitor => this works
    • {record.UniqueId} to link the document with the original forms record => this doesn't work
    Any idea why the first magic string works but the second doesn't?
  • Warren Buckley 2106 posts 4836 karma points MVP 8x admin c-trib
    Jan 15, 2018 @ 15:06
    Warren Buckley
    Hi Stief,
    I think this is a bug as I was not able to get this to work.
    Have we documented that this should work or was this working previously at all or was this in Contour?
    Either way its a bug and I suggest you log an issue on the tracker if one does not already exist for this
    http://issues.umbraco.org/issues/con
    Warren
    Jan 15, 2018 @ 19:41
    Stief Dirckx
    @Warren This is the first time I'm using Umbraco Forms, so I don't know if this worked in an earlier version. But I tried it after reading the Umbraco Forms' documentation on 'Magic strings'. It says:
    Where can I use these magic strings? These magic strings as we call them can be used in Workflows property/settings.
    I reported 2 related issues on the tracker:
