  • neelesh 9 posts 99 karma points
    Jan 24, 2018 @ 10:34
    neelesh
    Having problem in Umbraco forms connectivity with database
    What should I write in Connection string? I am using Microsoft SQL Server 2012
  • Mark 91 posts -18 karma points
    Jan 24, 2018 @ 10:47
    Mark
    Your connection string should look something like this:
    server=SQLServerName;database=MyDatabaseName;Integrated Security=True
    You may need to add your username and password for the database if it isn't a local database
    server=SQLServerName;database=MyDatabaseName;user id=MyUserName;password=MyPassword
    Jan 24, 2018 @ 13:50
    neelesh
    This is the error occurring from your solution
    Jan 24, 2018 @ 13:55
    Nik
    Hi Neelesh,
    This website is great for helping construct connection string:
    https://www.connectionstrings.com/sql-server-2012/
    Looking at your screen shot if you scroll down that page to the SQL Server Native Client 11.0 OLE DB Provider it gives you a variety of examples that should help you construct your connection string :-)
    The site is great for various different types of connection and database types.
    Nik
    Jan 24, 2018 @ 14:00
    neelesh
    Hi Nik,
    Great Solution and it works.
    Jan 24, 2018 @ 14:10
