Workflow editor not working without debug=true in web.config
I have a problem with the Workflow editor not working, unless i have compilation debug set to true in the web.config. When the setting is not present or set to false (which it should be in production environment), the Workflow editor does not work, but throws error like this in the console:
Any ideas?
We are running on an "old" Umbraco 7.2.4 with Forms 4.4.4. For different reasons updating the components are not possible.
Check that any references to DependencyHandler.axd are actually loading some JavaScript.
One difference setting compilation="debug" makes is to load JS from the original file URLs rather than going via DependencyHandler.axd, so if there's a problem with DependencyHandler.axd then setting compilation="debug" makes the problem go away. (I found this when I had ClientDependency config in a subfolder rather than the root.)
All references are loading and i know it disables the ClientDependency handler when in debug mode. Rest of forms functionality works fine and it only has a single JS, which is loaded, so something else must conflict.
Any ideas?
