  • Shahzad Ahamad 51 posts 251 karma points
    Apr 20, 2018 @ 10:13
    Shahzad Ahamad
    How to read Form values in workflow
    I have a contact form with some fields. Please find below the image of the fields.
    I need to fetch the email value which customer provides while submitting the form in the workflow here. enter image description here
    Also there is a dropdown in the form can I read the value selected by the user in the workflow?
    Any help would be appreciable.
    Thank you
  • Kerri Mallinson 113 posts 497 karma points
    Apr 20, 2018 @ 11:21
    Kerri Mallinson
    Hi Shahzad,
    Just so I understand, you want the workflow to send an email to the email address that the user enters in the form?
    If so you need to enter the field alias enclosed in {} in the 'Email' field in the workflow settings: eg {email} or {emailAddress} or whatever the field alias is you have used.
    Kerri
    Apr 20, 2018 @ 11:29
    Shahzad Ahamad
    Hi Kerry,
    Thank you for your response.
    But can you also tell me how to find the alias name of the form fields because I cannot find it in the form.
    Can you please also suggest me how to get the selected value from the drop down as I need to send it as the subject of the email
    Apr 20, 2018 @ 11:34
    Kerri Mallinson
    Hi, the alias is grey text above the field name on your form, eg:
    It should be the same for getting the subject line - put the alias for the field you want to use inside {} e.g. {howCanWeHelpYou} (or whatever your alias is
    Apr 20, 2018 @ 11:40
    Shahzad Ahamad
    Hi Kerri,
    I know that benter image description hereut it is not available in the form
    Apr 20, 2018 @ 11:49
    Kerri Mallinson
    Thats very odd! Does it show if you click on the settings for the field here?
    Apr 20, 2018 @ 12:00
    Shahzad Ahamad
    I already tried, its not even there.
    Apr 20, 2018 @ 12:15
    Kerri Mallinson
    I cant think of why it's not showing - maybe try a different browser or its a bug with the version you have perhaps.
    If you have access to the database you can get the alias from this table: [dbo].[UFRecordFields]
    or you can try to guess and test it, they usually generate as the name of field without spaces or special characters and camel case e.g
    Email would be {email}
    Email Address would be {emailAddress}
    First Name would be {firstName} etc..
    Sorry I cant be more help
    Apr 20, 2018 @ 12:24
    Shahzad Ahamad
    Thank you for your help Kerri, I have the database access I will try to get the alias name from there.
    Apr 20, 2018 @ 13:29
    Shahzad Ahamad
    I got the alias name from the form json file in \App_Plugins\UmbracoForms\Data\forms
