  • Robin Mikaelsson 2 posts 72 karma points
    May 22, 2018 @ 08:55
    Robin Mikaelsson
    Umbraco form does not work on mobile
    Some of the input fields in our Umbraco form change from input to a normal div container when on mobile or simply resizing the browser window so the "burger menu" appear. This makes the input unusable, but only some of them (Firstname and Email).
    Using Umbraco version 7.7.4
    Would appreciate some help.
    May 22, 2018 @ 09:21
    Robin Mikaelsson
    It seems to be a problem with having them in 2 columns as in the picture: enter image description here
    We have some forms that are simply lined top to bottom in 1 column, and those forms work on mobile mode.
    Anyone know if this will be resolved if I update the Umbraco site? Or some other workaround, Thanks.
    /Robin M
