  • KB 3 posts 73 karma points
    May 24, 2018 @ 11:40
    KB
    Umbraco Forms Prevalue Source problems
    i have a problem with forms and prevalue source. I have a node called Trips and a custom prevalue source that uses the trips node to populate the prevalues.
    When i create a trip i save in the Content section. And i expect the newly created trip to showup in the dropdown. But when i run the site the trip dosent show in the dropdown where i use the prevalue source. For me to see the trip i have to save it in the prevalue source aswell (first in content then save in prevalue source).
    I want to be able to create a trip and save it in content, whitout having to save it in the prevalue source. I have subscibed to the ContentService.Saved event, and from there my idé is to save the prevalue source programmatically is that possible?
    Thankful for any help! Best regards / Joakim
  • Tito 314 posts 623 karma points
    Nov 15, 2018 @ 15:54
    Tito
    I have the same issue, have you got around this?
