Template not saving 404 not found umbraco/RestServices/SaveFile/SaveTemplate Umbraco Forms
When I was trying to save the template, I can't able to save the template and also I didn't get any error message.
But in Chrome console I can able to see the following message "404 not found umbraco/RestServices/SaveFile/SaveTemplate".
In App_Data I was getting the following error,
ERROR Umbraco.Web.Scheduling.ScheduledPublishing - [Thread 5] An error occurred with the scheduled publishing System.Net.WebException: The underlying connection was closed: The connection was closed unexpectedly. at System.Net.WebClient.UploadDataInternal(Uri address, String method, Byte[] data, WebRequest& request) at System.Net.WebClient.UploadString(Uri address, String method, String data) at System.Net.WebClient.UploadString(String address, String data) at Umbraco.Web.Scheduling.ScheduledPublishing.Run()
By any chance is this site running on HTTPS and do you have a URL Rewrite setup to redirect traffic received on HTTP to HTTPS. Sometime you get that error in the log files when Umbraco makes a request on HTTP and it gets redirected to HTTPS.
If so have you tried setting the umbracoUseSSL to true in the web.config, this will force Umbraco to use HTTPS.
When I was trying to save the template, I can't able to save the template and also I didn't get any error message. But in Chrome console I can able to see the following message "404 not found umbraco/RestServices/SaveFile/SaveTemplate".
Hi Gokul,
Let me know if that helps.
Andy
Hi Andy
We use HTTPS URL Rewrite rule on our site. We receive this Error only for a particular Template. All the others are working Good.
Gokul Sridhar
