i.e. i have two form on the page form1 and form2, both have fields that require validation.
here are my steps:
Is it a bug that would be fixed? Or this is just by design? If so, are there any workaround for this problem?
Thank you.
Hi Alexi,
We are also facing the same issue with Umbraco version 8.1.1 and using Umbraco Forms: 8.2.0
Are you able to find the solution ?
Submitting form after another one triggers validation for first submited
here are my steps:
Thank you.
Hi Alexi,
