Umbraco web site in Azure VM takes 3 minutes to load
Our umbraco site is hosted in Azure VM. There couple of more sites hosted in the same VM. Until yesterday everything was working fine. But from today(there was no deployment) we are facing performance problem in one web site.
It takes more than 3 minutes to load each page everytime. I found out that first request has over 3 minutes waiting time.
I have connected to the same DB from my local and it loads fine. So there is no issue with the DB.
Also Umbraco admin portal loads without any issues as well.
Thanks for your time on this. I have updated the deployment content and it is working fine now. Not sure what is the issue. I suspect some of the scripts files are corrupted.
You can see by your self from following url,
http://centrepoint.attractor.solutions/
Any help would be highly appreciated.
Thanks!
I clicked the link you provided, and the page loaded in a couple seconds, so maybe it is just a problem specific to your network?
Thanks again!
