  • GTona 6 posts 76 karma points
    Jul 24, 2018 @ 15:08
    GTona
    FileUpload filed max size
    Hi everybody, is ther any way to limit file upload size without acting at web.config level? I mean is it there the possibility to evntually extend componet in order to block user upload when a certain size is reached or intecept upload and generate an error?
    Thanks for kind answer
  • Aaron Yarborough 2 posts 75 karma points
    Jul 24, 2018 @ 15:16
    Aaron Yarborough
    The HttpPostedFileBase class has a property named ContentLength which can be used to determine file size.
    More on HttpPostedFileBase here: https://msdn.microsoft.com/en-us/library/system.web.httppostedfilebase(v=vs.110).aspx
    public ActionResult Upload(HttpPostedFileBase file)
        if (file.ContentLength < 1024)
            // File is too large
    Jul 24, 2018 @ 15:22
    GTona
    Thanks Aaron for you flesh answer. You are right, but how can I apply this approach to Umbraco From FileUpload field? Maybe my question is silly, but I don't know how to do it.
    Thanks again
  • Jeffrey Schoemaker 408 posts 2138 karma points MVP 8x c-trib
    Jul 25, 2018 @ 06:12
    Jeffrey Schoemaker
    Hi GTona,
    we've created a package which does exactly this: https://our.umbraco.com/projects/backoffice-extensions/umbraco-forms-on-perplex-steroids/.
    Kind regards, Jeffrey
