  • Jennyfer 13 posts 126 karma points notactivated
    Aug 02, 2019 @ 15:33
    Jennyfer
    Issue with prevalue items with comma
    We have this scenario that the checkbox list items contains comma i.e. Doe, Jane Lee, Ann Test, Sam
    So when we select both 'Doe, Jane' and 'Test, Sam' The value stored in UF Records Table is 'Doe, Joe,Test, Sam'.
    How we can handle this case? Is there a way to reconfigure the delimiter to other string value?
    Please advise.
  • Alan Draper 34 posts 116 karma points
    Oct 23, 2019 @ 15:10
    Alan Draper
    Did you get an answer to this? I'm having a similar problem with validation of a pre-value that includes a comma.
    The select option is "$20,000 and up" and
    I'm getting the validation error "Unexpected value: '$20'. Expected one of these: 'Under $10,000', '$10,000- $15,000', '$15,000 - $20,000', '$20,000 and up'"
  • Nik 1549 posts 6848 karma points MVP 5x c-trib
    Dec 23, 2019 @ 13:58
    Nik
    Hi Both,
    Just to give an update, I've raised this on the issue tracker for Umbraco Forms
    https://github.com/umbraco/Umbraco.Forms.Issues/issues/260
    There is no easy fix unless you know a way to replace the UmbracoFormsController
    Nik
    Dec 23, 2019 @ 16:14
    Alan Draper
    Hi -- I already raised this issue on the issue tracker for Umbraco Forms, and they have fixed it (I think) but it is not released yet.
    https://github.com/umbraco/Umbraco.Forms.Issues/issues/243
